586,106 active members*
2,987 visitors online*
Thread: UCcnc CAM
    Oct 2005
    1145
    UCcnc CAM
    Well it is cute. Unless what I see is because it is in demo mode they have a long way to go for it to be usefull. It is VERY picky about the importing of a DXF. Most files I have here will not load I get an error about it not being an autocad200 format. I normaly use V14 dxf and it is 99.99% compatible with everything I try except this one.
    When a dxf does load the image is distorted in one one of the axis. When the toolpath creates it is WRONG, Most of the elements are in the wrong place.
    You cannot rename a layer.
    It does not seem to understand the order of operations that you create. There is no list to see them or change them.
    Like I said , long way to go to be usefull.
    (;-) TP
    Re: UCcnc CAM
    While it's nice to have one package to do everything, the fact is that there are many free options avaialable with a lot more power.
    Spend the time on getting the control finished, and add the "Accessories" later.
    If I were to do a custom UCCNC screen, I'd probably leave this part out.
    Jul 2006
    41
    Re: UCcnc CAM
    I agree with you, I do not see this CAM as a priority. THink CNCdrive should put all the effort in making the CNC trajectories and a good user interface
    etc. as they did.
    There are many prof. and none professional Cams with special features out there that attend all needs perfectly well.
    Re: UCcnc CAM
    Dear Sir,
    I have seen some posts about the screensets in UCcnc where can we get new screensets for Uccnc ?
    Do you know any in German language to download ?
    Best regards
    MfG Günter
    Oct 2005
    1145
    Re: UCcnc CAM
    UCCNC is NEW to custom screensets. For the time being I would stick to a stock screenset until they get a few more features working as teh screensets COULD change quite a bit and by using a custom screen you would not have access to newer features that were added on.
    I personally am holding off releasing ANY custom screensets to the public at this time. NOW can you build a nice screen??? . OH MY YES . You can make it look like ANYTHING you can imagine. BUT at this point user SUPPORT of it would be very time consuming for a screen developer because of all teh upcoming changes.
    Just a thought, (;-) TP
  1. UCCNC Macro sharing
    By BanduraMaker in forum UCCNC Control Software
    Last Post: 02-04-2023, 12:17 AM
  2. Honest Appraisal of UCCNC
    By Bad Wolf in forum UCCNC Control Software
    Last Post: 01-10-2018, 01:45 PM
  3. UCCNC owners and support thread
    By shorton in forum UCCNC Control Software
    Last Post: 08-25-2017, 12:07 AM
  4. Getting Started with UCCNC Software
    Last Post: 02-08-2015, 07:06 PM
  5. UCCNC software release
    By dubble in forum News Announcements
    Last Post: 06-13-2014, 02:24 PM
