586,069 active members*
3,463 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PathPilot™ > Are there any commands to write a .txt/.tap file from a Gcode?
Results 1 to 6 of 6
    Dec 2012
    161
    I've been playing around with a probe and was considering writing a program to do some inspection. Are there any commands where I could actually write a file? Really, just a simple text file along the lines of:
    #<x_1>=(random numerical value)
    #<x_2>=(random numerical value)
    #<x_3>=(random numerical value)
    Dec 2008
    740
    Re: Are there any commands to write a .txt/.tap file from a Gcode?
    The standard linuxcnc deployment comes with a number of examples which appear to be missing in the Tormach distribution. Check out the Grid Probe and Smart Probe examples described here:
    G Code Examples
    I've attached the samples for reference (I haven't tested them). This may not be exactly what you're looking for but it might get you started.
    Step
    Edit: also search for PROBEOPEN in G Codes - this is probably more useful.
    Dec 2012
    161
    Thanks! Exactly what I was looking for.
    Aug 2010
    130
    That works great in PathPilot. I calibrated and checked out the probe, and loaded the program. It went to work.
    However, I have tried everything I can think of, but cannot find the file it creates. I believe it is creating a file because if I edit the file name to include a bad path, it says it is an error and the file doesn't open. I added a path to Z:\Probe\probe-results.txt or .ngc, and I do not get the error, but I cannot see any file.
    My controller is networked, and I cannot find any file from a PC on my network. I have tried searching all of "Z" with the name, and for all files created today, but cannot see any results file.
    What do I need to do to be able to see the file?
    Thanks.
    Aug 2010
    130
    I finally figured it out. I will start a new thread about the digitizing and the path to the file.
    Oct 2008
    44
    Quote Originally Posted by Tbkahuna View Post
    I am looking forward to reading the new thread! Thank you!
    Kevin
  1. U and V axis commands in Gcode.
    By AzzA2032 in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-04-2014, 07:42 AM
  2. Simple GCode Reference / Commands?
    By WarrenW in forum G-Code Programing
    Last Post: 11-30-2010, 10:03 AM
  3. write gcode
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 11-28-2010, 09:33 AM
  4. Ok, how do I do write a simple program in gcode?
    By Apples in forum G-Code Programing
    Last Post: 11-18-2010, 02:42 PM
  5. Gcode commands for Plasmacam
    By jeffery71 in forum PlasmaCam
    Last Post: 11-01-2010, 02:50 PM
