This is a lynx 200 lathe , start to pull 50 to 80 amps normally on idle , start at 50 and goes up to 80 and shuts down , we trace up to the inverter and on the entrance of the 3 face is the load not showing any load (amps) on the motor if is not working like should be
we send it to repair but they say it is ok they tested and work fine no problem found on the inverter , we connected after receive it and same problem does any one have any idea what else can be .
another board ?
this unit is a beta unit and has the spindle , x and y servo on the same unit
the unit # is A06B - 6143 - H203#A
any idea
