586,065 active members*
4,327 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Machine cutting thing far too big or too small. (Laguna Swift 4x4)
    Aug 2015
    5
    *Note: I'm not trying to spam the forums, I just posted this originally in the wrong subforum*
    **Also, please excuse my mistyping in the thread title. I have work in 20 minutes and I was in a rush*
    Hello,
    My brothers and I just bought this Laguna 4x4 Swift CNC Router. I'm pretty much the only guy who can kinda run it.
    While testing a few programs, I noticed some big problems.
    1. Projects seem to be really really tiny when not modified (Inches). They do seem to be cutting correctly,
    2. The same project becomes gigantic with a G20 code added in. Also the arcs go diagonally.
    3. The same project, but in Milimeters, also comes out gigantic (No G20 or G21.). However, the arcs are okay
    4. I tried to cut the outline of a guitar. I don't have the code for this one, but it was to scale somehow. However, the arcs were super messed up. Picture included.
    Here's the test code.
    (PROGRAM NAME - PART1)
    (3/8 STRAIGHT BIT TOOL - 1 DIA. - .375)
    N100T1M6
    N110S18000M3
    N120G0G90X-.9375Y.625Z1.25
    N130Z1.1
    N140G1Z0.F100.
    N150X-.5625F500.
    N160G3X-.1875Y1.I0.J.375
    N170G1Y2.
    N180G2X1.Y3.1875I1.1875J0.
    N190G1X5.
    N200G2X5.1875Y3.I0.J-.1875
    N210G1Y1.
    N220G2X5.1326Y.8674I-.1875J0.
    N230G1X4.1326Y-.1326
    N240G2X4.Y-.1875I-.1326J.1326
    N250G1X0.
    N260G2X-.1875Y0.I0.J.1875
    N270G1Y1.
    N280G3X-.5625Y1.375I-.375J0.
    N290G1X-.9375
    N300Z.1F100.
    N310G0Z1.25
    N320M5
    N330M30
    The machine uses a RichAuto A11 controller, I think.
    Is there something I'm missing? We literally hooked this up yesterday. I would call Laguna but they're not open on weekends, so I thought to give these forums a shot.
    Sep 2006
    6463
    Re: Machine cutting thing far too big or too small. (Laguna Swift 4x4)
    I think you need a short course in G code planning.......go to UTUBE for a couple of free tutorials and videos.
    Ian.
    Aug 2015
    5
    I've already taken a course where I had to hand write all my G-code. In that class I used Fadal's on aluminum. I also know how to use a HAAS, and on that I used wood.
    The code I posted is the one Mastercam exported. Vcarve also made pretty much the same code, besides starting at a different point, but the coordinates were the same. I don't see anything inherently wrong with it. I think this controller has some odd setting I don't know about.
    Sep 2006
    6463
    Well, the other solution is to examine the machine itself and see if the screws are all snug and without much backlash.
    Before you even consider anything that you want to make, do a few tests like making a square or a circle and test the results......any deviation from squareness or roundness and you have the answer........it could also be in the settings of Mach3...... whatever etc.
    Ian.
    Aug 2015
    5
    After much testing I found the biggest Issue. My pulse settings were at 400 instead of 100! Changing that Fix the size issue and everything cuts to size.
    Now my only problem is cutting in Inches (G20) creates those diagonals intead of nice arcs,
  1. Replies: 0
    Last Post: 08-08-2015, 07:41 AM
  2. Laguna Swift 60x120
    By druuzy in forum Want To Buy...Need help!
    Last Post: 04-08-2015, 04:28 AM
  3. Replies: 1
    Last Post: 04-26-2012, 11:34 PM
  4. My machine is cutting parts to small
    By clocksandblocks in forum Linear and Rotary Motion
    Last Post: 03-16-2010, 11:52 PM
  5. Small but not junk? Is there such a thing?
    By MychesterCNC in forum CNC Machining Centers
    Last Post: 02-01-2010, 04:42 AM
