Hi ALL, I see the UCcnc has a G31 probing Gcode. BUT I do not see where you can retrieve the trip point values that should be stored as a system # variable. M3 used 2000-2003.
Actually I do not see a list of ANY System # variables.
Hard to create a probing routine without the trip values(;-)
Also it would be nice to have Probe tip comp were you can input the probe tip diameter and it COMP the trip values for center line values instead of edge values.
Also missing is a calibration routine to calibrate the probe for TIP diameter comp( tip radius + switch travel) AND XY offset from Spindle centerline.
(;-) TP
