586,077 active members*
3,599 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Drilling cycles in X5
    Jun 2015
    76
    Hi
    Beginning to work more with solids in Mastercam I have a little problem when I chose points in different heights on the solids. When generating codes my G79 puts out the lowest coordinate as the initial Z value, so the first hole is at the lowest value. I want it to be in Z 0, as I want to drill holes before I mill.
    The Program looks like this:
    %PM9000
    N9000( 15-019-0013 )
    N1 G18 T1 M6
    N2 G52 M8
    N3 G81 Y5. Z-1. B5. F300.0 S3000 M3
    N4 G79 X182. Z24. Y-3.
    N5 G79 X164. Z35. Y0.
    N6 G79 X81. Z35. Y0.
    N7 G79 X122.5 Z35.5 Y0.
    N8 G79 X150. Z47.5 Y0.
    N9 M5
    N10 T0 M6
    N11 G74 Y-1
    N12 G74 X-1
    N13 M30
    Any way to fix this?
    I haven't had such problems before, as I only have worked with DXF files.
    Cheers, Daniel
    Mar 2011
    4
    Re: Drilling cycles in X5
    I would just create a layer with the points at Z zero and be done with it, or alternatively change the depth by going into the geometry tab and altering the z depths on all the holes after the first one.
  1. Sinumerik 840c/840D drilling cycles
    By claudiu220405 in forum SIEMENS -> Sinumerik 840C
    Last Post: 01-25-2012, 07:50 PM
  2. Need help in Cincinnati A850 drilling cycles.
    By keyancnc in forum Cincinnati CNC
    Last Post: 02-27-2011, 04:51 AM
  3. Heidenhain TNC 2500 Drilling Cycles
    By cossiegaz in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-24-2008, 05:31 AM
  4. Drilling cycles
    By inflateable in forum EdgeCam
    Last Post: 04-30-2008, 08:42 AM
  5. drilling and drilling cycles tutorial
    By wmorre in forum MetalWork Discussion
    Last Post: 10-19-2006, 12:30 AM
