Hello
can we assign entry point for tool path at some distance away from job.
Just like in master cam , there is point ( location )specified entry for toolpaths.
where is this option in solid cam?
Hello
In the links sections / lead in / inside the drop down you can find the 'point' option
Hello
For 3d milling ,inside the leadin there is no point option,
there are
1 normal
2 arc
3 tanget options but no specific point option.
But even when i use normal option in 3d milling (selection of working geometry center)
it prompts
there is lack of space for leadin & out.
How it can be solved?
But i need the one specific point option away from tool path at some distance.
yes , point option is available in 2d operations but not in 3d milling.
Please how it can fixed?
its very good , if it will explained by some video tutorials.
thanks
