Hi all !
I'm new in the world of CNC, i got a good understanding of electromechanical stuff and computer, but im stuck while trying to set my home limit switch.
I got a limit switch on X, Y and Z, im trying to set them in the port input setup and each time im triggering Y i got an e-stop. The CNC isnt mine, my friend had pluged the 3 limit switch with a 9v battery with led for his origin, i've studied Mach3 and found that i could set up the limit switch in the program and avoid breaking anything. There's a 6 pin (male) identified limit switch with X,Y,Z, on the YOOCNC board, so i pick up an old 6 pins (female) connector i had and plugged the 3 limit switch on the board, i've searched on the net and on this forum for info on setting them in Mach3, tried some stuff and i dont understand why the e-stop keep going up each time i trigger the Y.
I started by setting X home, Y home and Z home all at port # 1. Then the pins X-home - 10, Y - 11 and Z - 12. When i REF ALL, the Z work, then it goes to Y and E-stop goes on. I've tried manualy the limit switch, the X and the Z works but the Y always pop up the E-stop. I've read about noise... I've unplugged the e-stop button on the controler, didnt work neither, so i guess my problem isnt noise. This morning i scrolled down the input and found that e-stop had 10 for pins, i though i had found the problem and was stupid haha , tried some combination with pins from 10-13 and 15, but the e-stop keep poping up.
I usualy try to find and correct most problems by myself with all the info we can find on the net and spending time to think about the whole thing, but now i just cant understand what im doing wrong.
I'm a french canadian for Quebec, my main language is french, sorry if i give headaches to those that gonna read this
Thanks a lot for any help you guys can provide me !
Meitral
Edit : I've tested some more stuff while watching kids playing in the garage ; I've unplugged the e-stop, unplugged the 6 pins connectors for the limit switch and tried to trigger them dirrectly on the board. Z and Y doesnt trigger the e-stop, but when i jumped the X, the e-stop pop up.
Can the board has some problem or there's a setting in mach3 that isnt right ?
