CNC 3-axis mini mill, flood coolant, enclosure, 5000rpm spindle
-Mill has been upgraded with a 1.5hp motor, belt driven which increases the spindle to 5,000rpms.
-The original motor and accessories function perfectly and will be included.
Tooling/Accessories
-comes with computer and MACH3 software to run the mill
-Tormach Satellite controller
-custom flood coolant system with electronic pump OR air actuated pump (have both, but air works best)
-Starrett edge finder
-PeeTools electronic LED edge finder
-Harvest 1/32?-1/2? drill chuck
-Spring gauge set
-6? Parallel set of 10 (little machine shop)
-Fly Cutter set (3)
-1/16? x 3? slitting saw
-Boring Head set (little machine shop)
-20pcs TiN coated end mill set
-Collet set: 1/8?, 5/32?, 3/16?, ??, 3/8?, ??, 5/8?, ??
-1-2-3 Blocks (2)
-Center drill set
-Extra coolant nozzle with magnetic base (double coolant nozzle also included already on Mill)
-Various end mills including ball mills, flat end mills, chamfer mill, roughing mill, etc. etc.
-Little Machine shop precision vise installed on mill
The mill runs great and holds pretty good tolerances. We converted the mill to use for proto-typing and have since purchased a Hurco VM10i to do our machining, so this machine is simply not needed. We are selling it to pay for tooling for the big mill.
-Mill itself (before cnc conversion)
3-axis mill from Little Machine Shop:
Link: http://www.littlemachineshop.com/products/product_view.php?ProductID=3900&category=138780768 3
The LittleMachineShop.com HiTorque Mini Mill is the best in its class. It has the most power, most torque, and a larger table than other mills in its class.
The 500 Watt brushless spindle drive motor provides tremendous low-end torque. And you can vary the speed from 50 RPM to 2500 RPM continuously. There are no gears to shift. And, with no gears, the HiTorque Mini Mill is the quietest in its class.
The large mill table provides 50% more table area than other mini mills. It also has 30% more travel in each direction. The resettable feed dials allow you to zero them at any point.
The HiTorque Mini Mill has drill press handles for drilling and fast motion of the mill's head. It also has Z-axis fine feed with 0.001" resolution for milling operations
Mill was converted to CNC with (www.cncfusion.com) kit with the best options available
-Pre-Loaded Ballnut Service
-Heli-Cal zero backlash coupling
The controller is from (www.probotix.com)
This kit:
http://www.probotix.com/3_axis_stepper_motor_driver_kits/3_axis_monster_stepper_motor_driver_kit/
Including:
-PBX-USB breakout board ($75 option)
-Ready to run large enclosure ($150)
-40VDC Linear RTR power supply ($75)
We do have a licensed copy of BobCAD-CAM which we can include for $500, otherwise there are various free or inexpensive CAD-CAM programs.
List Date: 8/13/2015
For more info, click here to view the original listing: CNC 3-axis mini mill, flood coolant, enclosure, 5000rpm spindle
On Sale For: $6,513.15 + $100.00 Shipping
Mobile friendly version: CNC 3-axis mini mill, flood coolant, enclosure, 5000rpm spindle
Go Mobile: Download the free Panjo iOS app now!
