586,072 active members*
4,659 visitors online*
IndustryArena Forum > MetalWorking Machines > Sharp CNC > Having Problems when Z axis is referencing home
    Jan 2015
    9
    I have a sharp 2007 2412 super mill mill, I'm been have a little issue with the Z axis not repeating when I shut the machine down over night. My tool heights I took the night before and when I start running the next day are off .100 of an inch in Z. Has anyone had this issue before? It started doing this I have no clue what could cause this.
    Nov 2014
    34
    Re: Having Problems when Z axis is referencing home
    the encoder is an absolute type, so I would say the problem is with mechanical parts, like loose gib or something.
  1. Referencing axis at 0.0
    By Mike 1948 in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2015, 06:21 PM
  2. Hitting limit switch when referencing all home
    By crane550 in forum DIY CNC Router Table Machines
    Last Post: 08-28-2012, 03:14 PM
  3. help referencing home (advanced)
    By Zygoat in forum Mach Software (ArtSoft software)
    Last Post: 07-08-2012, 12:27 PM
  4. 18i-TA zero return (home referencing)
    By padobranac in forum Fanuc
    Last Post: 03-18-2009, 09:31 PM
  5. Z Axis Home Position Problems
    By JMFabrications in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2006, 04:58 AM
