586,058 active members*
4,691 visitors online*
Thread: New to CNC
Results 1 to 5 of 5
    Aug 2015
    3
    New to CNC
    Hi
    Im very new at CNC
    I bought a CNC from china Multitech 1313 (wood and soft metals)
    i was pretty sure when i order it the controller was to hook up to my PC (wanted to use mach 3) but came with a DSP control which i dont like very much
    I've had a programmer come over to help,which he did but cant seem to find the right code for this to work right tried gcode a piece 24"x24" came out the size of a coin
    tried a bunch of others did not read finally tried gcode arcs finally came out the right size but didnt controll the spindle speed
    emailed china not getting much help from them go fiqure
    how hard would it be to change the controller to Mach3 and where is a good place to buy the controller
    Im in the edmonton area
    Don
    Jun 2015
    943
    Re: New to CNC
    most of these machines comes with conventional step and direction drives so only the DSP control has to be removed and the drives and sensors connected to the LPT port or motion controller and configured in mach3.
    For this ofcourse you need to have some knowledge of electric wiring and a wiring diagram of the machine control box can be really handy for the conversion process.
    Jun 2010
    4256
    Re: New to CNC
    A coincidence?
    Just a thought: if it came out 24 mm x 24 mm, then maybe the machine is set to the wrong units for your g-code?
    Cheers
    Roger
    Jun 2015
    943
    Re: New to CNC
    good point Roger.
    Aug 2015
    3
    Re: New to CNC
    hi
    ya tried different codes the one that's close is model master.mmg
    seem to work
    Don
