Re: Aluminium cutting the first time. Correct numbers??
As Andrew pointed out, clearing the chips is critical to avoiding snapped bits and rough finishes, and the use of WD-40, while the fumes are not good for you, is invaluable for stopping the aluminium gumming up the cutters. Just a tiny spray every so often is enough to stop the cutter bogging down.
I also use lanolin spray as it's not harmful while machining, but on the smaller machines like 6040's, WD-40 probably works best.
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
