Hey guys, been lurking here for a while and finally decided yo build a Joe 2006
For now I am in the "gather info" part so a few doubts have come up
1) While assembling the Z Axis carriage, where do the TOP 2 threaded rods go?. There is the Y Axis Bearing Block (HDPE) and the Z Axis carriage top plate (MDF) that seem to go next to each other and the threaded rods go through the Y Axis Bearing Block (HDPE) or below it (seems difficult to drill the piece from side to side)? Would it be bad if I make it go below the Y Axis Bearing Block (HDPE) and not through it?
2) I don't know which pieces are used to assemble the antibackslash piece as I couldn't find any closeups.
3) The assembly PDF mentions 3 tipes of couplers (Bore LoveJoy Coupler, Keyway Spiders and Bore LoveJoy Coupler) and 3 of each, are all of them required or are them three options to use? Would it be much different if I used these type (I couldn't find Lovejoys in my country).
Well that's it for now, sorry for the mistakes, English is not my main language :P
Best regards!
