586,111 active members*
3,522 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > DYNA EM3116 CNC Knee Mill system parameters needed
    Jul 2011
    36
    Firstly I'd like to say ANY help on this matter is much appreciated.
    I can't seem to run any programs lately, throwing a soft limit over-travel warning (- direction) on the Y axis half way through every time. In the system parameters I did notice all axis except the Y are set at 2000 ppr, the Y is at 4000. So far so good, and things are starting to add up to this being my problem. Until I get into the parameters menu, make the appropriate changes and try to save. A warning comes up saying 'these are not default settings' and reverts back to previous settings.
    Can anyone confirm weather this should be 2000 ppr as I suspect? Also, any suggestions as to how I can make this change stick.
    Thanks again in advance, H
    Jul 2011
    36
    Re: DYNA EM3116 CNC Knee Mill system parameters needed
    Managed to get the 2000 ppr to stick today using Caprirs method. Doing this caused an encoder reading warning so I am figuring 4000 ppr must be correct. Doesn't put me any closer to fixing the problem tho...
  1. Mechtronics-Dyna EM3116 cnc knee mill
    By shoptalk00 in forum Want To Buy...Need help!
    Last Post: 02-16-2023, 05:02 AM
  2. Dyna Mechtronics cnc Knee Mill need help with control
    By wisp in forum Knee Vertical Mills
    Last Post: 01-08-2021, 05:20 PM
  3. Information on a DYNA EM3116 CNC Knee Mill
    By shoptalk00 in forum Dyna Mechtronics
    Last Post: 01-08-2012, 12:41 AM
  4. DYNA EM3116 Manuals
    By adnanahmad in forum Dyna Mechtronics
    Last Post: 08-05-2011, 12:32 PM
