586,036 active members*
3,913 visitors online*
Results 1 to 9 of 9
    May 2008
    1185
    internal single speed belt drive
    Hi guys; I listed for sale the first belt drive I ever made for the IH mill. It is used and works fine.
    It is a single speed internal drive with a rubber mounted motor plate to fit a 185TC.
    I have a video or tow on youtube of the drive.
    https://www.youtube.com/watch?v=4dmfP5i2syQ
    And a really quick shot from the outside.
    https://www.youtube.com/watch?v=WacnLxxvohE
    The listing is for 30 days. I will take the best offer.
    I can answer any questions at [email protected]
    I can sell direct too.
    Thanks Guys.
    Dave
    youtube videos of the G0704 under the name arizonavideo99
    May 2008
    1185
    Re: internal single speed belt drive
    I lowered the price of the belt drive to $300 if anyone wants it.
    Mar 2013
    13
    Is this working with the original Lesson motor? What is swapped out and/or what is needed?
    May 2008
    1185
    The motor plate is for a 185TC motor. The motor needs a long shaft but the pulley takes a QC bushing so any motor shaft size is OK. The shaft does need to be about 2" or longer.
    I can drill the plate to take any other motor face mounting. The 185TC is a big face so everything else is smaller.
    I just dropped the price to $250.
    The motor I used was a 3hp 3650 RPM. It worked fine. The pulley ratio is .9 to 1 under drive so a 1750 RPM is not the best unless you want about the same RPM as stock.
    I could turn the high speed pulley down a bit if you want more speed. I need to check it for clearance.
    May 2011
    31
    PM inbound
    Jan 2015
    Hi i tryed to pm you but it did not work. Is this still for sale?
    May 2008
    1185
    I still have it.
    contact me at [email protected]
    Mar 2013
    13
    I would have been all over this (The Gear noise is driving me nuts) All the Googling, I can not find that motor.
    May 2008
    1185
    The single speed drive has been sold to a IH owner.
    Thanks guys.
    Dave
  1. Solsylva build in progress : dual X-axis motors VS single w/belt drive
    By Frederic Gagnon in forum DIY CNC Router Table Machines
    Last Post: 02-17-2012, 11:43 PM
  2. Small single-point internal threading
    By SweetJustice in forum MetalWork Discussion
    Last Post: 10-24-2010, 03:58 AM
  3. Internal Threading Speed Recommendation
    By dgoddard in forum MetalWork Discussion
    Last Post: 12-24-2009, 09:29 PM
  4. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
  5. Replies: 1
    Last Post: 06-30-2007, 03:30 AM
