586,043 active members*
3,719 visitors online*
    Jul 2004
    235
    Konnect Board with Kflop: Using 4 Boards?
    Greetings,
    In a previous discussion, regarding the connect board; or I read something somewhere??? it was said "you can only use or access, one board at a time"?
    I thought I could use all four boards at once? Control 64 out and receive 128 in?
    I am thinking of using your system to Automate a Bottle Filling Line.
    Thanks so much?
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    May 2006
    4045
    Re: Konnect Board with Kflop: Using 4 Boards?
    Hi Jeff,
    Not sure what you mean. It is certainly possible to use all 4 boards at the same. Communication to the 4 boards does take some time and is performed individually. With a 4 board configuration the boards are all updated every 720us.
    https://youtu.be/gQkyiI_FyTw
    HTH
    Regards
    TK
    http://dynomotion.com
    Jul 2004
    235
    The video did explain it well.
    Not sure what I say or read... mis-information I guess.
  1. Replies: 42
    Last Post: 01-28-2016, 03:37 PM
  2. Replies: 6
    Last Post: 08-21-2015, 07:24 PM
  3. Kflop/Kanalog/Konnect - MR-J2S-xxA and everything in between
    By wheeliecake in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-25-2014, 02:21 AM
  4. G40, G41, G42 / Problem with G41 & G42? Ver. 4.32 Kflop board.
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-07-2014, 06:54 PM
