When using the Mach3 built in debugger, I can't seem to get the breakpoints to work as I expect.
I set a breakpoint on a line of code. My expectation is that if I click "run", than the program will execute to that point and stop there, wait for me to press run, or step, again.
But when I press run, the script runs, passes the breakpoint, apparently ignoring it. I do not have the breakpoint nested inside some control structure that is being bypassed. I'm setting it on lines that are being executed when I step through the code one line at a time.
Are the breakpoints functional? How do you use them if they are?
