Hi All,
I've had a bit of a hunt around and can't seem to find any discussion on my problem (sorry if I've missed it).
I have a Chinese laser (50w) which I've been using for about 2 years very happy with it.
The current problem is that I am having issues with cuts in MDF not going through in different places on the bed.
EG: top strip (y axis) first 3 cm is patchy ie. cut is dotted. For the rest of the Y axis cut is fine.
So just to be clear when I cut a 50cm x 30cm sheet: 50cm x 3cm is not cutting through the remaining 50cm x 27cm is cutting fine.
I've spent 3hrs aligning the laser and think it is close (bugger of a job!).
The bed is level.
Laser tube has been replaced about 3 months ago.
Before I pull it apart and do it all again I'm just wondering if it could be anything else?
