586,106 active members*
3,113 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Need post processor for Camworks - Mach 3
    Aug 2015
    Hi, I'm a newbie; I have Mach 3 installed on my 3 axis cnc router and would like to generate toolpaths for it in Camworks 2015. File format: .tap
    I a need a suitable post processor and I need instructions on how to install it in Camworks.
    Thanks!
    Aug 2008
    1186
    Quote Originally Posted by Willem1000 View Post
    Thanks!
    You will need to use the UPG and a Fanuc Generic Post to start start from. This video is in Spanish, but it is pretty easy to follow along with the changes he is making for it to work. Also, I believe Camworks outputs posts in txt format which is fine for mach 3, bit if you want to change it to tap file extension you will need to copy the .pinf file set from another post in the millsrc folder and change the name inside it and the file extension output from txt to tap. There is a great video on YouTube that goes over doing this.
    Here is to adjust the lost:
    https://youtu.be/0ohD1SU9a00
    Here is some good information about the UPG
    https://youtu.be/vXe0s5IbpC4
    https://youtu.be/oH0LGqd3se8
    You need to learn these so you will be able to tweak it for your machine. If you don't have home and limit switches you will need to do some creative thinking on how to write the tool change operations as most use the home limits to reference the machine before setting the work offsets and then use the machine coordinates for the tool change position. That could be potentially dangerous or cause crashes if the machine coordinates aren't the same every time.
    Good luck, it isn't that bad and at the end of it you will have a much better understanding of how posts work and how to adjust them to suit your specific requirements!
    Aug 2015
    Re: Need post processor for Camworks - Mach 3
    Thanks, I'm out of town until end of the week; will then give it a try.
    May 2015
    here u go, add these to your post directory
    https://www.dropbox.com/s/swq3osp7kr...works.zip?dl=0
    May 2015
    Quote Originally Posted by law-of-ohms View Post
    Thanks, will these work with 4 axis Mach3 controller?
  1. Replies: 3
    Last Post: 01-12-2014, 02:35 PM
  2. need post processor heidenhain 530 or 407 for camworks
    By suzoki in forum Post Processor Files
    Last Post: 01-09-2014, 12:35 AM
  3. CAMworks / EMC2 post processor
    By spacewalker in forum LinuxCNC (formerly EMC2)
    Last Post: 01-11-2012, 09:10 AM
  4. Post processor for Camworks
    By debutpic in forum Screen Layouts, Post Processors & Misc
    Last Post: 05-22-2005, 09:27 AM
