586,069 active members*
3,446 visitors online*
    Aug 2015
    Looking for a PWM Motion Controller
    I am helping my friend fix his CNC mill that is setup with a ProtoTrak M3 retrofit. Recently he was getting a few errors at startup and strange readings on the DRO. Now none of the axes will move and the DRO stays blank.
    We have determined that the slave board (motion controller) is dead, since the status LEDs don't light up and the firmware is not listed when requesting the status.
    Instead of sending the controller back to SWI for an expensive refurbished unit with next to no warranty, he wanted to look at using LinuxCNC or Mach3 (or any other open source/cheaper software) because he found the capabilities of the ProtoTrak a little limited and tedious to program.
    Since the servo drives are still in good condition, we would like to reuse them. However I am having trouble finding a motion controller that would be capable of outputting 2 PWM signals for movement control.
    I have found 2 similar threads here:
    http://www.cnczone.com/forums/knee-v...74574-cnc.html
    http://www.cnczone.com/forums/dynomo...ervo-amps.html
    It appears that the only controller capable of this is the Dynamotion Kflop? Or are there other options out there?
    Jul 2003
    1754
    Re: Looking for a PWM Motion Controller
    I think all Mesa cards like the 5i25 can output up/down pwm. (so could the printer port - but you are limited by the speed at which the computer can do it)
    (linuxcnc)
  1. CNC USB motion controller
    By Kroko in forum News Announcements
    Last Post: 01-03-2014, 01:58 PM
  2. Motion Controller
    By Joshua Sendawul in forum Multicam Machines
    Last Post: 07-31-2013, 03:22 AM
  3. Choosing a motion controller
    By spangledboy in forum Controller & Computer Solutions
    Last Post: 03-31-2013, 11:07 AM
  4. Yaskawa Motion Controller
    By curtisturner in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-08-2008, 07:27 PM
  5. PARKER 6K2 or 6K4 Motion controller
    By TUCSONCNC in forum Post Processors for MC
    Last Post: 02-02-2007, 07:07 AM
