So I have a AB ultra 3000 dsd-010 hooked up to an AB mpl-a420p-h, I have selected the motor for the drive in the configuration software, when I try to tune the motor is either very jumpy or it will whine while holding still. The drive is under rated for the motor but in the book it shows this motor being able to use a drive that doesn't provide enough juice for the motors full output potential. When I run feed back diagnostics/tests it passes all of them, with manual shaft rotation. Any ideas on what could possibly be causing this, or maybe what I'm not doing to get it to work?
