586,069 active members*
3,398 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > Welding caused bend. How to straighten the square tube?
    Mar 2014
    1131
    I welded some 40x40x4mm iron tubes. The tube is 1 meter long. I've been very careful not to bend it got bent anyway. Now I need to straighten it. What is the best way for this? Heat, hit with an axe, jumping on it?
    Thanks.
    Jan 2010
    17
    Re: Welding caused bend. How to straighten the square tube?
    heat the side thats curved outward. The shrink of the heat will pull it back.
    So if you made a T-joint, heat the side without the welds.
    Nov 2015
    6
    I have always welded one side a bit then the other an so on so the heat is the same both sides I was a coded welder years ago last job was on channel tunnel
  1. How To Bend this Tube?
    By sodfarmer in forum Bending, Forging, Extrusion...
    Last Post: 10-02-2011, 11:14 PM
  2. Square hole in square tube
    By bubblybill in forum MetalWork Discussion
    Last Post: 09-21-2009, 04:18 AM
  3. Best Way to Bend Aluminum Tube ???
    By twocik in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2009, 07:39 PM
  4. Square Tube Welding Done Right!
    By boguski.1 in forum Welding Brazing Soldering Sealing
    Last Post: 09-30-2007, 06:13 AM
