586,067 active members*
5,115 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Double Ball Nut on 1605 Thread Problem
    Jun 2014
    7
    Has anyone experienced a double nut that only screws half way on before getting stuck - at about the point that the second nut starts the thread?
    Not sure if there is blockage between nuts where the spacers sit or maybe extra balls installed....... These are new nuts, first time installed. One of two
    worked just fine. Problem occurred on the X axis screw (G0704 build).
    Any suggestions much appreciated.
    Jul 2007
    1602
    Re: Double Ball Nut on 1605 Thread Problem
    That is the whole point of a double nut. There is preload between the two nuts and that that preload force must be overcome before the second nut can start threading. That is how the double nut removes backlash. The force can be considerable.
    http://www.nskamericas.com/cps/rde/x...d_Rigidity.pdf
    bob
    Jun 2014
    7
    Quote Originally Posted by rowbare View Post
    bob
    Hi Bob - thanks for the reply.
    There was a hard stop when the second nut came up to the threads. Not a tight fit that needed 'persuation'. I tried claming the nuts axially to try to minimize the starting preload...but no help I'm thinking debris or extra ball, or something amuk with the spacers between the nuts
    I'm familiar with repacking single nuts but wary of any extra steps if I dissasseble the double nuts.
  1. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  2. Stuck 1605 Double Ball Nut
    By The Geekineer in forum Benchtop Machines
    Last Post: 08-27-2015, 10:03 PM
  3. Question about 2005 and 1605 Ball Screws
    By hive8 in forum Benchtop Machines
    Last Post: 10-29-2013, 08:11 PM
  4. double ball nut assembly
    By ethan scott in forum Uncategorised MetalWorking Machines
    Last Post: 06-08-2011, 10:05 PM
  5. Double ball nut cam loose - Desperate for help!
    By wwendorf in forum Linear and Rotary Motion
    Last Post: 08-06-2007, 05:49 PM
