LF3015c Fiber Laser Machine
High quality laser tube: IPG500W
Untouched following system
Yasukawa servo system
Imported ball screw and linear guide rail driving system
Auto partitioned exhausted system
Industrial chiller
Off-computer control system (Supported files: DXF,PLT,AI)
Attachment 290902
Technical Specification
Working area:1500mm3000mm
Dimension4100X2100mmX1900mm
Positioning accuracy:±0.05mm/m
Positioning speed:20m/min
Weight:5000kg
Power supply:220V±10%/20A
Capability
stainless steel
carbon steel
Galvanized sheet
Speed
Material
m/min
carbon steel 1mm
8
carbon steel 2mm
4.2
carbon steel 3mm
2.1
carbon steel 4mm
1.2
stainless steel 1mm
7.2
stainless steel 1.5mm
stainless steel 2mm
1.8
galvanized sheet0.8mm
5
galvanized sheet1.2mm
2.6
galvanized sheet1.5mm
1.8
Running cost
Electricity cost
1-3KW
Laser gas
Not
Assisted gas
Oxygen/Nitrogen/compressed air
The parameters showed are based on the client actual working situation,only for reference!
The assisted gas will be used according to the different materials (such as stainless steel and carbon steel).
