Is there software to program the machine path to the actual tool paths? I have been just modifying code to make it work and is very time consuming. A lot of my moves cannot contain straight to, short distance moves.
The machine is supposed to follow the toolpath generated by your CAM software. Where did you get this code, and how does the motion of the machine differ from the toolpath?
Can you try to explain what you mean a little better?Is there software to program the machine path to the actual tool paths?
The toolpath is being generated by my cam software just fine. It's the path TO the toolpath that I am changing. I can't do a rapid, shortest distance to the toolpath. My workpiece is taller than my z clearance. I am currently doing this by manually editing the code but it is time consuming.
Does your CAM software allow you to define fixtures? (not the G code workspace offset type of fixtures, the CAM modelling feature of fixtures for no-go zones). Might be worth using, if it does, it's exactly what they're for.
Failing that, does your CAM software (or post processor) allow you to define blocks of G-Code to be inserted at the start of a job? Might be able to run a generic startup path around the perimeter of the work envelope to your standard starting position if you have one.
You might be able to create a fake geometry in the CAD model going to your CAM package which will lead to a desired initial toolpath. Maybe, anyway.
Otherwise it's cut and paste time.
