586,100 active members*
2,737 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > NEED HELP!!! spindle not working 6040z cnc
    Aug 2015
    I've recently purchase a 6040z 4 axis cnc machine. I've finally got the axes moving with Mach 3 but am still having trouble understanding what a VFD is and why my spindle won't speed up. The spindle is a water cooled 1.5kv.
    Apr 2004
    5737
    Re: NEED HELP!!! spindle not working 6040z cnc
    VFD stands for Variable Frequency Drive. 3-phase spindles, unlike normal induction motors, go faster when the frequency of the electricity they're fed increases. Normal US electricity comes in at 60hz frequency, but the VFD will boost it much higher. If you've got the spindle running, what happens when you twist that white dial?
    Andrew Werby
    Website
    Aug 2015
    I do not have the spindle working but when I turn the dial, nothing happens. If I change the spindle speed in Mach 3 the numbers on the vfd go up but the spindle still does nothing
  1. Need manual for 6040Z black spindle box
    By MarioCCH in forum Chinese Machines
    Last Post: 11-20-2015, 03:44 PM
  2. NM-145 Spindle not working
    By overrev in forum Novakon
    Last Post: 04-21-2012, 04:02 AM
  3. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  4. Spindle not working on X3
    By EugeneJohn in forum Benchtop Machines
    Last Post: 03-29-2010, 03:33 PM
