586,055 active members*
4,395 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > Can DRV8825 Stepper motor drive power a 425ozInch/3Nm stepper?
    Sep 2015
    Question Can DRV8825 Stepper motor drive power a 425ozInch/3Nm stepper?
    Hi i just bought everything for my new cnc machine but i only just realised that the drivers i bought for my stepper motors have a limit of 1.5 amps, and my steppers require 3.5amps
    here are the parts in question
    http://www.elecrow.com/drv8825-stepper-motor-driver-module-p-1347.html
    CNC Shield for Arduino(GRBL Compatible) [COP5511CNC] - $20.00 : Elecrow bazaar, Make your making more easy
    and
    http://www.aliexpress.com/item/Out-O...959569193.html
    I plan on building a cnc with a 1mx0.5mx0.3m milling space, linear rails, screwball rods etc. as this is large i panicked and bought large steppers (for fear of not being able to move my plywood gantry) and without checking if my driver can power them, I'm hoping against hope that maybe i'm worrying about nothing, I've invested quit a bit with equipment surrounding my DV8825 drivers so if i need to change anything it will be the steppers,
    the description of my DV8825 drivers says "It operates from 8.2 – 45 V and can deliver up to approximately 1.5 A per phase without a heat sink or forced air flow"
    does this mean that each motor can have 3 amps as there is 2 phases per motor? and that if i have a heat sink and fan (which i do) then can I up the amps even further, to the required 3.5?
    if there is indeed a problem here can you guys recommend the cheapest way out as i'm broke after buying all this equipment.
    thanks in advance i don't know who else to ask!
    Re: Can DRV8825 Stepper motor drive power a 425ozInch/3Nm stepper?
    The answer is yes but it's Not good choice for long time running.
  1. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  2. stepper drive power supply
    By CNCpatriot in forum Stepper Motors / Drives
    Last Post: 01-20-2012, 01:51 AM
  3. Power Supply for 4 Stepper Driver 32-65VDC and 4 Stepper Motor 65V 2.3A
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 12:50 PM
  4. ?? How to drive the Stepper Motor
    By eein in forum CNC Machine Related Electronics
    Last Post: 08-30-2007, 02:40 AM
