586,080 active members*
3,662 visitors online*
IndustryArena Forum > Community Club House > International / Regional Forums > USA Club House > Z-Axis Tool Path is Higher than Z-Axis Zero
Results 1 to 3 of 3
    Aug 2015
    3
    Just finished building my first CNC. I'm using the Chinese blue board with Nema 23 270oz motors and Mach 3 (R3.042.020) on a dedicated Windows XP computer (no other software installed). I have a zero plate probe installed on pin 15. Everything on the machine works great except that when I zero the X-axis (manually or via the zero-plate), the z-axis tool path is higher than the zero. For example, I was running an engraving g-code, created in Photo VCarve, and the cut depth was 0.01". After zeroing the machine, I ran the g-code and the tool ran just above the material surface, almost grazing it, but never cutting into it. I had to change my zero plate thickness in Mach3 from 0.060" to 0.075" just to get it to cut into the material. Even then, it still wasn't accurate depth. When I tell it to return to zero, all 3 axis return to where they are supposed to be - correct zero.
    I've re-zeroed and re-confirmed zero multiple times, using multiple g-codes, from multiple sources, and the z-axis tool path is always a little higher than the z-axis zero.
    It's almost like the z-axis zero is set to the bottom of the tool cut depth. I tried some V-bit letters in a block of scrap wood as a test, and I had to zero the z-axis 1/8" lower than the material surface in order for the bit to cut 1/8" into the wood.
    Am I missing a setting somewhere??
    I am a total noob to Mach3, and CNC in general. Thanks guys!!
    Mike
    35538
    Re: Z-Axis Tool Path is Higher than Z-Axis Zero
    What auto zero script are you using, and how thick is your touch plate?
    Aug 2015
    3
    Gerry. Below is the code I'm using (exactly as copied from the web). My plate is 0.060" thick
    CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
    CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
    CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
    If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
    DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
    Code "G4 P3" ' this delay gives me time to get from computer to hold probe in place
    Code "G90 G31Z-4. F4" 'probing move, can set the feed rate here as well as how far to move
    While IsMoving() 'wait while it happens
    Wend
    ZProbePos = GetVar(2002) 'get the exact point the probe was hit
    Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
    While IsMoving ()
    Wend
    Call SetDro (2, .060) ' change .060 to your plate thickness and then adjust for final accuracy
    Sleep 200 'Pause for Dro to update.
    Code "G1 Z1. F50" 'put the Z retract height you want here, must be greater than the touch plate thickness
    While IsMoving ()
    Wend
    Code "(Z axis is now zeroed)" 'puts this message in the status bar
    Code "F" &CurrentFeed 'Returns to prior feed rate
    Else
    Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if applicable
    End If
    If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
    Code "G91"
    End If
    If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
    Code "G0"
    End If
    I got that code from this YouTube tutorial: https://www.youtube.com/watch?v=G4DeVa8rzA0
    Thanks! ~Mike
  1. 4 Axis Rotary Tool Path
    By aldepoalo in forum BobCad-Cam
    Last Post: 12-06-2013, 12:29 AM
  2. which multi axis tool path
    By juxtoposed in forum Mastercam
    Last Post: 10-24-2012, 01:41 AM
  3. 4-Axis CAM and Tool Path Problem
    By skibbey in forum Uncategorised CAM Discussion
    Last Post: 03-13-2007, 04:05 PM
  4. C axis tool path
    By Capt Crunch in forum Mastercam
    Last Post: 12-21-2006, 02:05 AM
  5. need help fast 5 axis tool path in mastercam
    By fasttom in forum G-Code Programing
    Last Post: 12-02-2005, 07:22 AM
