586,477 active members*
3,771 visitors online*
    Sep 2015
    Miyano BNC12S Parameters
    I just Bough a Miyano BNC12S Fanuc OT and the B axis doesn't do what I tell it to do
    it doesn't
    like the G110 (if I can Only able to use this that will solve all my problems) command or the G102 or G103
    The G101 it reads but only 2 or 3 lines and it ends the canned cycle
    please if some one can help me out with the parameters
    thank you in advance
    Oct 2006
    100
    Re: Miyano BNC12S Parameters
    Did you get a copy of the parameters ?
    I am looking for the electrical diagrams for this machine. I can send you a copy of the ladder diagram.
    It has no address descriptions.
    - - - Updated - - -
    Mar 2017
    314
    the Miyanos that use the 0T control and the g110 are a super pain in the butt.
    If you have the manuals, they do not behave exactly as they describe. The g101 behaves in a unpredictable manner for me and i wont use it.
    you have to have
    G110 T71 or whatever you are using for the b offset, on the first line
    then
    G110 Bx on the next line
    this is moving away from B ref return pos. The workholding must be open to move in the B- direction.
    sample pickoff
    N170T808(CUTOFF)
    (HOLDER #ISCAR SGTHR 19-3)
    (INSERT #GTR 3-15D IC354)
    (TOOL SET LENGTH 1 5/8")
    (DW 1480)
    G97S800M203
    G0X1.125Z1.
    G99
    Z-0.012
    M117
    G110T71
    G110B0.
    M118
    M08
    G04X0.5
    G1X1.1F0.001
    X0.6
    M09
    G110T70 (T70 cancels the B offset)
    G110G0B-2.5 (return to B0 would cause Z overtravel on subspindle operations)
    G0X7.
    Z4.
    M205
    M25
    M00
    final tool of sub ops with part catcher routine
    N200(FINISH FACE AND TURN)
    (HOLDER #SANDVIK SVJBR 12 2B)
    (INSERT #VBMT 2[1.5]1-UF 1025)
    (SCREW # 5513 020-03)
    (TOOL SET LENGTH BUMP TO STOP)
    (DW 4565)
    T2222
    G97S1190M194
    M191
    G0X1.1232Z-1.M8
    Z.0233
    G50S2000
    G96S350
    M191
    G1X1.0232F.0025
    X.9858Z.0046
    G3X.9637Z0.0R0.0111
    G1X.875
    Z-.05
    G0Z-1.
    X4.
    M9
    G0X6.Z-1.
    T0200
    M105
    M09
    G110B0.0
    G04X0.5
    M35
    G04X1.0
    M117
    G04X2.
    M36
    M213
    M30
  1. Miyano BNC34 Parameters
    By Mark18969 in forum Fanuc
    Last Post: 07-20-2022, 01:07 AM
  2. Miyano JNC-35 Lathe Parameters
    By MildBill in forum Uncategorised MetalWorking Machines
    Last Post: 11-05-2020, 01:54 AM
  3. Replies: 1
    Last Post: 12-02-2019, 05:46 PM
  4. Miyano BNC12S Parameters
    By enjoymfg in forum Tormach Personal CNC Mill
    Last Post: 09-03-2015, 08:55 PM
  5. Miyano MSV-21 Parameters
    By billay in forum Uncategorised MetalWorking Machines
    Last Post: 07-06-2011, 06:50 PM
