Re: CNC Maintenance Record Program
I see you said you have outgrown excel? Have you made macros and such to make the task easier? I have a spreadsheet which I used some old macros from college and high school; I use it actively to keep track of what days I complete the task and how long the task takes on average. I would suggest that if you've reached a point where you're thinking you may need a new program to do this that you "re-vamp" your sheet. If in doing so you do not achieve what you were thinking of, then I would suggest getting a version of quickbooks on your PC. It is a little over the top considering your specific need here, although quickbooks can be used for many, many different things. Hopefully this may have helped you a little bit.
"The one who follows the crowd will usually go no further than the crowd..."
-Albert E.
