586,075 active members*
4,095 visitors online*
    Oct 2012
    17
    mach3 - Z axis counter shows unspecified values
    Hi . A few days ago i have noticed that Z axis counter in mach3 does not display correct values which are set up in safe Z and other settings, and Z axis does not "keep highs".
    For example:
    when I click Cycle start Z axis goes up in Safe Z and counter shows 24.9996 ( predefined value 25.0000 in Mach3)), and when toll plunge in to material (final-flat deep) it shows 2.0009 (predefined value 2.0000 (in Vcarve)) , also rapid Z gaps move shows 2.0009 ( predef.values in V carve 2.0000).
    Also when I press STOP Z Axis goes too high and hit in limit switch. When I press "gotozero" counter shows 0.0000.
    I tried reinstaling Mach 10 times , also I tried other version of Mach, but I can not fix a problem. As I understood - Mach just send signals to driver and does not recieve return informatio what machine did.So I assume it is Mach or comp !?
    Does anybody have any ideas about this problem.
    thank you in advance...
    Re: mach3 - Z axis counter shows unspecified values
    1) Mach3 does not go to Safe Z when you click Cycle Start.
    2) Where are you setting Z zero? The top of the material is typically Z=0, and cutting moves are negative Z values.
    3) Is your Safe Z set in Machine Coordinates or Work Coordinates. If you don't want it to crash, it should be set to Machine Coordinates, and you should Home the Z axis each time you turn on the machine.
    Apr 2004
    5737
    What kind of machine are you using where discrepancies of less than a thousandth of an inch matter to you? If it's a router, that's the least of your worries.
    Andrew Werby
    Website
    Just to clarify, the difference between 2.000 and 2.009 is probably due to your step resolution.
    Oct 2012
    17
    People thank you very much for taking the time to answer.I have home made machine, and im engraving letters in stone . its dc servo motors/drivers. I started to pay attention to above mentioned when I noticed that the Z axis is not "holding height". Koncretely, each additional letter that I engraved was shallower by 1/10 mm, so I suspect that Mach is not working well. I reinstaled mach and its better now. The next thing I'll do is reinstalling the VCarve.Thank You again, I will follow what happens
    Attachment 291690
    Attachment 291692
  1. In simulation it shows round but on machine it shows polyline please help
    By amritsingh in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-18-2015, 10:28 PM
  2. Replies: 1
    Last Post: 06-11-2014, 02:53 AM
  3. Replies: 3
    Last Post: 01-16-2012, 03:05 AM
  4. FANUC 6TB Unspecified Alarm on Download
    By smithy2167 in forum Fanuc
    Last Post: 08-15-2007, 03:14 AM
  5. Unspecified failure message
    By Chrisjh in forum Syil Products
    Last Post: 07-04-2007, 01:57 PM
