586,419 active members*
3,189 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Need help building a simple standalone stepper driver box
Results 1 to 10 of 10
    Mar 2014
    6
    Question Need help building a simple standalone stepper driver box
    Hi all,
    This isn't specifically for CNC, so I hope it's ok to ask for help here.
    I recently bought a Jet 12x36 metal lathe, and I'd like to add a very fine longitudinal feed to the lead screw for doing finishing cuts.
    I have a smallish 5-wire (unipolar?) stepper motor that I pulled from a plotter. It has a word gear on the end, and a plastic gear that it meshes with. I think I can adapt that drive system fairly easily to my lathe.
    What I'm hoping to do is buy or build a control box that will give me simple low-RPM constant rotation in either direction.
    I'd like a FWD-OFF-REV switch (or some equivalent) and a rotary knob that I can use to adjust the rpm. The exact rotational speed is not important.
    I need to avoid any sort of computerized control, so I can make the box rugged and mount it to the lathe somewhere.
    I know this is doable with an Arduino or similer, but I'm hoping to end up with something much simpler.
    I realize the motor itself is an unknown, and I'm trying to look up the specs on it. I know it's a 25V DC stepper, made in Germany by Buehler. It's HP part #C 4699 60032 if that helps any.
    Is this possible, or am I dreaming?
    If it turns out that such a product exists at a reasonable price, I'm happy to just buy it and be done.
    Thanks in advance for any help you can offer,
    -Mike
    Dec 2007
    2134
    Re: Need help building a simple standalone stepper driver box
    Sounds like your over thinking it, a stepper is going to require not only a stepper driver and associated reasonably high VDC power supply, but also some sort of signal conditioning and control signals to actually drive it.
    A simple geared DC motor with a forward/reverse switch, and a speed control is what would be most practical and dirt cheap. You'll probably spend $20-$25 all up off ebay. Simple DC speed controllers for a vast array of motors are amazingly cheap on Ebay.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Mar 2014
    6
    Possibly, but the motor itself is a cost as well, whereas I have the stepper.
    I'm a fan of reusing equipment where possible, but I'm not a fan of throwing away money.
    My other thought about using a stepper is the basically infinite range of speeds, all the way down to 'can't hardly see it turn'.
    It seems like there should be an easy way to do this, I just have found it yet....
    Dec 2007
    2134
    You can buy really simple stepper controllers on ebay for peanuts that will provide the same simple forward/reverse and speed control. For what you want though, a DC motor will be the simplest and most reliable. Steppers aren't really that ideal in continuous mode, certainly not compared to DC motors anyway..
    cheers, Ian
    Mar 2014
    6
    "You can buy really simple stepper controllers on ebay for peanuts that will provide the same simple forward/reverse and speed control."
    Yes! This is exactly what I need. Do you have a link for an example or even a particular description to search for?
    I'm not looking for a stepper driver that is made to interface with a microcontroller, such as an Arduino or similar.
    I need a standalone driver, that can take input power and drive the stepper with a couple switches and a speed control knob.
    -Mike
    Dec 2007
    2134
    Well there's ones like this I'm fairly sure would be crappy, but it's dirt cheap so who cares:
    DIY Speed Stepper Motor Click Driver Controller With Remote Control 9 Levels | eBay
    This one is possible very less crappy, and you can team up with a cheap driver to achieve what you want:
    DC12V Stepper Motor Speed Pulse Controller Speed Direction ON OFF Control | eBay
    There's plenty more if you just search "stepper driver -arduino" on ebay, and just look for ones with a pot.
    cheers, Ian
    Mar 2014
    6
    Sounds like this is more complicated/expensive than I want to get into right now.
    I figured there was a simple way to drive a monopolar stepper with a couple components and a simple circuit. Guess not.
    Thanks anyway.
    -Mike
    May 2007
    74
    Quote Originally Posted by Elmojo View Post
    Thanks anyway.
    -Mike
    Mike I have been researching the same thing for about two weeks now, I did find this one on eBay.
    CNC Stepper Motor Step Dir Pulse Generator | eBay
    I plan on buying another version of this, reverse engineering it and building more for myself and the one I thought to buy is $34.00 includes shipping, this one connects to the stepper motor driver, driver connects to the stepper motor. It will give you full control, speed and direction. I am also looking into just building my own 556 timer version. Hope this has helped some what, Jeff.
    Jeff's CNC Plasma Cutting
    Dec 2007
    2134
    Or you could just buy any of the dirt cheap H-Bridge boards on Ebay and a cheap DC motor that's designed exactly for what you want, and still have heaps of change left.
    Seems strange to me to try and cobble a more expensive solution with steppers to simply have them emulate a DC motor.
    cheers, Ian
    May 2007
    74
    Well you are correct in a sense, but if you think about it, there would be many other applications for this type circuit (testing and checking CNC movements is one). In my case, I already have most of the components to build the circuit, also have about 10 stepper motors and a few drivers to chose from, without spending money.
  1. Stepper motor simple driver
    By Pysiek in forum Stepper Motors / Drives
    Last Post: 11-14-2014, 11:13 PM
  2. building stepper motor driver
    By rashdan in forum Open Source Controller Boards
    Last Post: 02-18-2012, 09:43 PM
  3. Need simple non-cnc stepper motor driver
    By BTD in forum Stepper Motors / Drives
    Last Post: 05-26-2010, 08:04 PM
  4. Standalone Driver
    By olf20 in forum Open Source Controller Boards
    Last Post: 04-20-2008, 05:12 AM
  5. Looking for simple stepper driver help
    By dubious in forum Stepper Motors / Drives
    Last Post: 03-14-2007, 07:19 PM
