586,070 active members*
3,500 visitors online*
Thread: steel tube 2
    Feb 2005
    16
    steel tube 2
    I would like to get a quote on a tube made of low carbon steel that has a inside diameter of three hundred and ninety two thousandths with five thousandths available on the positive side for the tolerance and the tube size from side to side measures four inches and a half and fifty thousandths plus and minus ten thousandths and on one side of the tube a turned diameter of eighthundread and twenty thousandths and one hundred thousandths wide and the last diameter of one inch and ninety two thousandths minus five plus zero and two hundred thousandths wide to be the second diameter from the same side of the tube to look like the shape of the letter t all other tolerances are plus and minus five thousandths
    Apr 2014
    432
    Re: steel tube 2
    I have worked in a tube mill and the forming rollers you are looking at may be cost prohibitive ,but you never know.
    Feb 2005
    16
    Re: steel tube 2
    I would prefer a quote from a person that has a small home lathe to machine the parts if possible
    Feb 2005
    16
    Re: steel tube 2
    I dont need the tubes anymore thanks.
  1. Square steel tube
    By wcarrothers1 in forum DIY CNC Router Table Machines
    Last Post: 12-02-2021, 09:32 AM
  2. steel tube
    By tizank in forum RFQ Feedback
    Last Post: 09-07-2015, 04:51 AM
  3. Deflection on rods and tube steel.
    By FunnyDream in forum Mechanical Calculations/Engineering Design
    Last Post: 07-14-2012, 10:22 AM
  4. Looking for 2" square steel tube.
    By danmickey in forum DIY CNC Router Table Machines
    Last Post: 11-16-2005, 12:22 AM
