586,103 active members*
3,274 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Question, Requesting help, schematic stepper motor step/direction & drive.
    May 2007
    74
    Cool Question, Requesting help, schematic stepper motor step/direction & drive.
    I would like to build a machine using a stepper motor (nema 17, 1.8 DEG., 200 SPR, 3 amps, 12 to 24 volts), that I can adjust speed of independently, also switch direction without software or being connected to a computer. Does anyone have a schematic that one could use/build from, to control step and direction along with a driver I could build to accomplish what I am requesting? Thanks Jeff.
    Jeff's CNC Plasma Cutting
    May 2005
    1397
    Re: Question, Requesting help, schematic stepper motor step/direction & drive.
    A standard 555 timer can be used to generate pulses.
    techref.massmind.org/techref/logic/555/555astable.htm
    Direction can be changed with a simple switch...
    techref.massmind.org/techref/io/keyswitch.htm
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    May 2007
    74
    Thanks James, I'll look into this as I have some time.
  1. DC Servomotor drive for step / direction
    By cswiger in forum Servo Motors / Drives
    Last Post: 09-28-2014, 02:04 PM
  2. Replies: 2
    Last Post: 06-12-2014, 11:08 AM
  3. Stepper motor step/Direction conversion.
    By shujah in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2009, 01:49 PM
  4. AC servo Step Direction drive
    By professor in forum Servo Motors / Drives
    Last Post: 11-10-2007, 05:07 PM
  5. Convert Step/direction to phase drive
    By jderou in forum Stepper Motors / Drives
    Last Post: 08-05-2005, 02:52 PM
