586,061 active members*
4,342 visitors online*
    Nov 2006
    Smile Help needed with Mori Seiki MV Junior post
    I need a post for Mori Seiki MV Junior milling machine, Fanuc 10M,(im running Mastercam 8.1), that seperates the tool select command from the tool change command putting it onto a seperate line.
    i.e.
    The standard post produces
    N100 T1M6
    I need the post to produce
    N100 T1
    N110 M6
    and will also move the Y axis to at least the 100mm from the reference point as required by the Mori for the tool change position, but still return to the XY reference point at the end of a job.
    Baxter I sent you an email
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Nov 2006
    Thanks for your reply Steve,
    I'm sorry for the delay.I am a very infrequent netter and I have been tolerating my present post processor for several years, so no rush. I will now be making sure that I have described all of the existing posts faults and then I will probably be in touch.
    Kind regards and happy Christmas. Baxter.
