586,121 active members*
3,758 visitors online*
Thread: Sweep Twist
Results 1 to 6 of 6
    May 2013
    701
    Sweep Twist
    Any thoughts on how to keep geom horizontal as attached?
    Dec 2011
    295
    Re: Sweep Twist
    Although Al sez that the profile doesn't have to be attached and perpendicular to trajectory. Try it attached and perpendicular anyway, maybe even attached to the midpoint of the trajectory. I'll try tomorrow.
    Dec 2011
    295
    Re: Sweep Twist
    I did get the model to untwist . Here is how I did it. I assume your trajectory is a helix and your profile is an elipse. I used cross section surface place the profile normal to the beginning of the trajectory ( same as a sweep). Than I rotate the profile 90* and advance 1/4 helixs' pitch. Copy as many times as needed to get to the end of the trajectory. This basically this b***h slaps Bob to unnerstan what Im talkin bout. Make sure the profiles attach point is the same as it advances thru the trajectory.
    May 2013
    701
    Re: Sweep Twist
    Quote Originally Posted by LeWhite View Post
    Is there a chance that you could post the file?
    I tried that also but still had a slight twist. Maybe I missed something.
    RAF
    Dec 2011
    295
    Re: Sweep Twist
    I dont know to attach the file from a mobile device, and because of Win10 security the Bob computer isnt on line. To create the model you dont need to create the helix but you do need to know its properties of diameter and lead. Create your profile in a non horizontal plane, away from Zaxis one radius. You have already done this. NOW rotate around Z 90* and translate Z-[lead/4] copy n times. Now using the cross section CAD stragety 'cross section surface' chain the profiles in order and direction.
    Caviat; the first sweep section will be distorted as Bob thinks the sweep is normal to the profile. There will be no twist, only first lap radial distortion. Trim to taste.
    May 2013
    701
    Re: Sweep Twist
    Thanks LeWhite
    I got it to work using Skin
    Thanks Again
    RAF
  1. 2 rail sweep
    By Gallchobhair in forum BobCad-Cam
    Last Post: 10-04-2013, 04:55 AM
  2. Sweep
    By Poul M A in forum Uncategorised CAD Discussion
    Last Post: 03-09-2012, 01:56 AM
  3. sweep problem
    By riverracer in forum Mastercam
    Last Post: 07-08-2009, 06:38 PM
  4. how do i get sweep to do more than 360 degrees ???
    By yamaha_r1 in forum Post Processors for MC
    Last Post: 09-21-2007, 03:41 PM
  5. Sweep?
    By tt_raptor_90 in forum Solidworks
    Last Post: 06-05-2006, 12:27 PM
