586,096 active members*
3,626 visitors online*
IndustryArena Forum > CAM Software > OneCNC > How to program for Air spindle
Results 1 to 5 of 5
    Apr 2016
    5
    Question How to program for Air spindle
    Hi ,
    Im trying to run a program where I'm using a high speed air spindle as the cutter. I have set the spindle speed in the program to 0 as the actual spindle housing must remain stationary.
    Im using a HAAS mini mill and an error 331 is coming up, which states that a numerical input is too high. Has any one had this problem and what did you do to overcome this. Much appreciate your help.
    Ollie
    Mar 2009
    88
    Re: How to program for Air spindle
    Hello Ollie,
    My guess is that you have to have sometype of spindle speed programmed. If it doesn't effect, your air spindle set up, programmed a minumum speed in your code(i.e., S1 M03), then try. If that's too low then program a higher speed then, use the feed overides down to 5%. Hope this helps
    Apr 2016
    5
    Quote Originally Posted by mtlhe View Post
    Hello Ollie,
    Hi mtlhe,
    Thanks for your reply. I found out that when writing the program in ONE CNC you have to give the spindle a speed above 50 for their to be no errors at the machine then you edit the program at the machine and remove the M03 bit of code and hey presto the program runs and the spindle remains stationary.
    Thanks for you reply and I hope this can help someone else and prevent them from banging their head off the machine for an hour...
    15362
    Quote Originally Posted by CNCOllie View Post
    Hi ,
    Ollie
    Just leave the spindle speed out altogether M3 etc is not needed to make it run in the X Y Z axes
    Mactec54
    Apr 2016
    5
    Thanks Mactec. You are 100%correct as I found out yesterday, I just had to remove the M03 part and away she ran like a dream. Thanks for the suggestion and help.
  1. Replies: 4
    Last Post: 03-06-2013, 07:56 PM
  2. How to program sub spindle as a tailstock
    By RMW in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-19-2012, 01:38 AM
  3. sub spindle program
    By ab24 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-23-2012, 02:07 PM
  4. How to setup and program sub-spindle on TL-25?
    By Aeon in forum Haas Lathes
    Last Post: 03-07-2008, 01:02 AM
  5. Spindle keeps shutting down during program
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 05-03-2007, 12:04 AM
