586,035 active members*
3,908 visitors online*
IndustryArena Forum > CNC Electronics > Rutex Products > Servo Drives > Help with electronic gearing
    Jun 2012
    266
    Hello. I'm in process of getting my machine put together and now working with my ac servo drives.
    I think I understand the theory behind electronic gearing but looking for a little advice I guess.
    My encoders are quadrature 2500 count so 10000 count per rev. I'm running 5mm ball screw with a 2:1 belt reduction system. Now if I leave this setting to default 1:1 at 500 khz this thing will be dog slow.
    Is there a good calculation to use where I can figure out this setting as well as able to tell mach what my pulse per unit is?
    Sent from my SM-N910V using Tapatalk
    Jun 2012
    266
    Re: Help with electronic gearing
    Nobody? I'm wanting to run this setup at about .01mm per pulse as my goal. I need to be able to cut the pulses into about half so that if I send say 10000 pulses to the drive, the encoder will stop after 20000 quadrature counts
    15362
    skubajon
    What Servo Drives are you using, most Drive manuals will tell you how to set the Electronic Gearing
    Mactec54
    Jun 2012
    266
    I purchased some aasd drives. The manual shows how but of course not what to set.
  1. Electronic gearing
    By EFI-Unlimited in forum CNC Machine Related Electronics
    Last Post: 07-26-2015, 12:14 AM
  2. Master and slave electronic gearing
    By rainman in forum Stepper Motors / Drives
    Last Post: 12-22-2010, 02:53 PM
  3. Electronic speed control vs gearing/belting
    By serriadh in forum Mini Lathe
    Last Post: 12-23-2009, 11:41 PM
  4. Gearing down...
    By snooper in forum Mechanical Calculations/Engineering Design
    Last Post: 08-03-2006, 05:26 AM
  5. Need help on Gearing
    By CAM_MAN in forum DIY CNC Router Table Machines
    Last Post: 04-05-2006, 06:23 PM
