586,115 active members*
3,350 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Creating a CHOOK
    Jun 2015
    16
    Creating a CHOOK
    Hey everyone,
    I was wondering if someone could tell me if there is a CHOOK that can solve my problem or who could write one for me.
    So in my mastercam files I import a lot of geometry and the parts change sometimes. Well everyone else in the company works in auto cad so I was wondering if there would be a chook that I could set to run every time I exit the file that would turn on all of the layers, do the "save some" option then select all of the geometry and save it as an autocad file with the same name as the mastercam file. This would allow me to make the small changes in mastercam to the parts then it would save to autocad when I exit.
    Thanks for all of the help!!
    Jun 2008
    372
    Re: Creating a CHOOK
    I think doing this is VB would be easier
    Aug 2015
    5
    i don't know if i understood your problem correctly.
    if having a multipartfile organized on layers and you change only one part from one layer and you want to save only the changed part without all the other parts
    you can use part secure the point under SAVE AS
    it saves only what you see at the moment on your screen.
    Save it under a new filename
    if necessary you can read it in again and put it back onto a layer of your choice
    by the way chooks are written in C++
    read the word as C-hook
    Quote Originally Posted by D3V3R View Post
    Hey everyone,
    Maybe try a macro?
    Sep 2008
    87
    Why exactly are you doing save some and selecting everything? If you just hit the save button, it will do exactly that in one click. The name will be the same name with a mastercam extension.
    Let me know if I am missing something.
  1. Creating 3D from 2D Help
    By mikemill in forum ArtCam Pro
    Last Post: 01-25-2015, 03:57 PM
  2. Replies: 0
    Last Post: 07-17-2014, 04:12 PM
  3. RAS2VEC CHOOK SCALES DOWN JPEG. WHY
    By metlshpr in forum Mastercam
    Last Post: 04-08-2011, 02:46 PM
  4. What is a parametric Chook?
    By stairgod in forum Mastercam
    Last Post: 06-17-2008, 02:27 PM
  5. Chook coding in Visual studio .net
    By EdOsgood in forum Mastercam
    Last Post: 10-01-2005, 09:14 PM
