I am having a problem with a particular feature. Attached is a file for a hydraulic cylinder end cap which has a boss on it. The feature that is labeled 70mm boss has a rough pocket that I used adaptive roughing on. Then I go back with a finishing end mill to finish the face using an advanced pocket without adaptive roughing and it looks fine in simulation but when I backplot it is not covering the whole face. I have attached the .bbcd file, .txt file, and (3) MP4 files. One is the simulation, one is the backplot and one is just a screenshot of the toolpath which is blue that I generated from the code in Version 20. I'm using Version 27 Build 1547 posting to a Haas VF2. Thanks in advance for any and all help.
Stephen
