As title says, what will be the limiting factor of a spimdle: is it the generated heath or the max rpm of the bearings installed?
Thanks,
Milosh
Thanks,
Milosh
Nobody?
Also rotor inertia and rotor balance is a dependent factor.
Al.
Albert E.
Thanks for the answers.
So, it looks like, it is not good idea to crank up 18000 to something like 20000. I believe installed bearings in this spindle (china made) are for max 18000.
@Al
I understand why balance, but don't understand why rotor inertia is a problem. Could you explain it please. Thanks.
Milosh
Albert E.
