586,075 active members*
4,167 visitors online*
IndustryArena Forum > CNC Electronics > Dmm Technology > DYN4 enclosure wiring help
Results 1 to 6 of 6
    Aug 2009
    20
    I'm hoping someone here can answer some questions I have on wiring it up. The manual I find confusing and not for an average self learning cnc'r like myself. I emailed DMM a few days ago and haven't heard back from them yet.
    I got a 60A molded case circuit breaker from msc, and hope I got what the manual says is needed, because at 100 bucks I hope it is.
    The manual has in it 2 magnetic contactors, and one common noise filter.
    I'm having the hardest time finding where to get this stuff and if it is the right thing.
    If anyone knows of what I need to get this DYN4 running and where to get it, I'd appreciate it.
    In the manual it says for single phase input, connect power supply to R and T terminals on connector T4. Does it matter which one is connected to the 110v hot (black) wire and which is connected to the neutral (white)?
    I have the T3 connector for the DYN4 drive that it says goes to a regenerative resistor, do I need to wire this up?
    I have 2 DYN4 drives, does that mean I need 2 sets of components?
    If anyone knows of what I need to get this DYN4 running and where to get it, I'd appreciate it. If anyone has any pics of theirs that would be nice too. Thanks
    May 2010
    48
    Re: DYN4 enclosure wiring help
    im kind of in the same boat
    i want to set everything up correctly and was about to start another thread about it
    but your thread is asking the same questions i would
    could someone please post pictures of all the components wired up
    to make it easy for us?
    Aug 2009
    20
    Quote Originally Posted by GM1G View Post
    Here is a pic of how mine is wired up. Attachment 324090
    Black wire from 110v source goes to large circuit breaker --> terminal junction block --> P on noise filter --> fuse --> L1 on Dyn4 Drive
    White wire from 110v source goes to large circuit breaker --> terminal junction block --> N on noise filter --> fuse --> L2 on Dyn4 Drive
    On the noise filter PE is connected where all the earth grounds are.
    One Black wire from terminal junction block goes to R on Dyn4 Drive
    One White wire from terminal junction block goes to S on Dyn4 Drive
    T3 doesn't need to be connected, I forgot what the DMM guy said for a reason but he said I don't need to.
    I got magnetic contactor but haven't installed it yet. I've just been plugging in the power cord to enclosure to a 110v outlet to turn everything on.
    Right now I'm only using 1 Dyn4 Drive, but when I set up the other one I will install another noise filter and fuses for that one as well.
    Hope this helps you out
    15362
    Quote Originally Posted by usmarine21m View Post
    R is always your Hot, not sure why you have a 60A breaker, in your case a 20A would be all you need for each Drive, 60A would be if you had 4 High Voltage Drives at 220V 3 Phase, It's best if you have one main input power Breaker, then individual Breakers suited to each Drive
    The filters you can find at any good electrical supply store here is one FN610-1-06 Schaffner EMC Inc. | Filters | DigiKey, just Google the parts you need, don't forget for 120v single phase supply for the logic L1 you need ( 1 ) Fuse ( 2 ) Fuses if you are using 220V supply for L1 L2
    You are not doing anything with the regen,so nothing to do there, not for normal use anyway
    Mactec54
    May 2010
    48
    the manual calls for 1 amp fuses before the logic power for the drives
    usmarine do you have these installed?
    also could you link to the breaker you have there?
    May 2010
    48
    hey did u ever get your setup going?
  1. Dyn4 and Arduino rs232 communication
    By JPMach in forum Dmm Technology
    Last Post: 08-20-2015, 06:40 PM
  2. DMM DYN4 Enable signal.
    By rob2290 in forum Dmm Technology
    Last Post: 06-02-2015, 01:18 AM
  3. Gecko 540 control enclosure wiring
    By jcjahner in forum Community Club House
    Last Post: 06-02-2013, 02:37 AM
  4. Electronics Enclosure pictures/wiring and fusing
    By ahaidet in forum Benchtop Machines
    Last Post: 11-16-2011, 02:52 PM
  5. Electrical Enclosure and Wiring.. HELP!
    By firestorm1284 in forum Benchtop Machines
    Last Post: 03-04-2009, 07:01 PM
