Hello
I would really appreciate some help in determining relative comparison between my Bosch Colt 1HP trim router and a Chinese spindle/control package I am considering.
The Bosch is adequate for my current needs which mainly is V carving in soft woods and engraving aluminum. I am also limited to what I can plug into a standard 20A electric outlet
so this setup caught my eye as a replacement as the bearings on my colt are on its last leg and I would prefer something a bit quieter.
If this isn't the way to go, perhaps a suggestion as a replacement for a similar package?
Thanks for your time.
The following are the specs from Ebay:
1.Air Cooled Spindle:
Spindle motor: New DC motor
Power: 600W
Operating voltage DC24V-110VDC
Maximum working current: 7.8A
Maximum Power: 600W
Rotation Speed :2000-13000r / min.
Torque: 600mN.m
Insulation resistance:> 2 megohm
Dielectric strength: 400V
Diameter: 57mm
Motor Overall length: 222mm (includes gripping parts and motor)
Axis collet Length: 43mm
Diameter of ER11 clamping holder:16mm
The spindle runout: about 0.01-0.02.
Connection:Red line connect -,black line connect +.Please don't connect on the contrary,or the motor will be reverse rotation.
Weight: 1kg
Can be used for engraving metal or nonmetal materials
2.Power Supply speed governor:
Power Supply :support for Mach3 system
Matching motor power: 50W ~ 500W
Dimensions: 190mm x 105mm x 60mm
Output current: 10A
Excitation output voltage C110V
The armature voltage output: DC0 ~ 52V
Input voltage :AC220V/110V
