Thanks for that Beefy
I see you are in Frankston. I am over in Cockatoo.
I guess "Z lock" is at least part of "Anti-Dive". Can't dive while it is locked.
That is Mach's part of the deal. Mach can see when travel slows down but the THC can't.
Yeah this is where the Proma info is a bit hazy. It has a setting for "sensitivity". What does that mean?
It might be a filtering of very rapid voltage changes, such as you might get crossing a cut.
Or it might just be a dead band where reaction does not happen untill a few volts change in arc. Sort of damper. Maybe a clever combination of both.
EDIT: Actually reading it again Proma only have a "Hysteresis" setting. And that only on the 150, not the SD.
