587,048 active members*
2,535 visitors online*
Thread: SAT files
    Nov 2012
    162
    SAT files
    I recently loaded a SAT file into X9. It came in OK but when I click a line the whole surface is selected. How can I choose a single line?
    Also how can I change it from wire frame to solid?
    Aug 2015
    5
    Re: SAT files
    its quiet okay to use sat files..
    if model is okay it should be possible to read it as solid.
    if not it will create a surface model you can everytime create the boundarycurves on your own
    use CREATE/ Curves/Surface
    there you have a choice to create it at only one side you picked or completly
    otherwise you can read it out in an other format and reread it ( e.g. Step) or just let mastercam do the job
    under SOLIDS you can sew model together as an solid
    there are many options you can use as you can see...
    did you had a view @ options of sat reader? if it shoudl read file as surface or solidmodel?
  1. Converting Illustrator files to Gcode files
    By acoop101 in forum Uncategorised CAM Discussion
    Last Post: 03-10-2023, 11:13 PM
  2. Replies: 2
    Last Post: 01-16-2016, 03:23 AM
  3. Replies: 10
    Last Post: 04-12-2014, 04:03 PM
  4. converting CT Scans [ dicom files] to cutting files
    By fiddlemakermike in forum WoodWorking Topics
    Last Post: 05-09-2013, 02:15 AM
  5. Convert files to Inventor files.
    By bartL in forum Autodesk
    Last Post: 02-04-2009, 06:38 AM
