586,077 active members*
3,856 visitors online*
IndustryArena Forum > CAD Software > Solidworks > add flatten surface command in solid works 2012
    Jul 2015
    12
    Hello
    May you suggest how can i add flatten surface command in solid works 2012 !
    As it is available in solid works 2015.
    I want to add up one command (flatten surface) rather than installing the full update version.
    Thanks for suggestion
    Regards
    Jul 2010
    46
    Re: add flatten surface command in solid works 2012
    You can't. Try rhino's unroll surface command after importing and exploding your solid.
    Jan 2014
    16
    Quote Originally Posted by lovely123 View Post
    Hello
    Regards
    Without too much work you should be able to use the sheet metal commands to create the flatten surface.
    Read the help files about sheet metal.
  1. Move command works until velocity command issued
    By madprinter in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-30-2015, 01:06 AM
  2. negative of a solid in solid works
    By ringanator in forum Solidworks
    Last Post: 02-09-2015, 03:58 PM
  3. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  4. M6 Command only works one time now with new computer setup
    By jevs in forum Mach Software (ArtSoft software)
    Last Post: 02-14-2013, 06:53 AM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
