I checked out what some of the guys have been doing with the vacuum motors. They are using them in setups on full sheets and they will have vacuum loss in the though cuts. They need all that extra CFM to maintain a good pull while some of the air is pulling through. I won't be faced with those same issues. I will not have any vacuum loss. If the system is tight enough, I could pull the vacuum and turn the valves and pump off. If it is sealed, it would not leak. Big if's there though. This is also why I went with this type pump over a vacuum motor. I am trying to reduce the shop noise somewhat.
Those guys have certainly designed an built some nice vacuum systems though. I saw one with 4 of those motors in it. Wow!
