586,096 active members*
3,754 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Z level finish, wont finish bottom of feature
Results 1 to 7 of 7
    Aug 2010
    188
    I'm machining a feature into a solid block and I am using "z level rough" and "z level finish" the problem I am having is that the finishing tool does not finish the bottom of the feature.
    1" endmill rough tool
    1" ballnose finish tool
    V26
    Dec 2008
    4548
    Re: Z level finish, wont finish bottom of feature
    Quote Originally Posted by jay_dizzle View Post
    V26
    Z level finish will only read/cut vertical stuff. Not planar stuff like on the floor there.... Another feature for the bottom could be used.....
    Aug 2010
    188
    Should I add another feature or change my finishing strategy all together?
    Dec 2008
    4548
    Either of those are options. It kindof depends on the outcome needed/wanted. I would say a 3rd feature for the bottom is probably easiest/best..... Sometimes trying to do an entire piece in one go takes a bit more.
    A third equaldistance toolpath limited to just the bottom area may be a good compliment to the zlevel finish on those walls!
    (if you don't have equal distant then a spiral or radial will work)
    Apr 2009
    3376
    Upload a ,zip of a .bbcd file and we get into it further
    Dec 2011
    295
    Flat lands; or figure an even number of increments to equal bottom of feature.
    Aug 2010
    188
    thanks for the replies everyone, i just added a third feature to finish the bottom and all is good, sort of. now im having trouble with choppy tool paths, i have created a new thread to deal with this. thanks again.
  1. Z Level Finish
    By RAF. in forum BobCad-Cam
    Last Post: 07-21-2013, 01:09 AM
  2. Z Level Finish!
    By kawman in forum BobCad-Cam
    Last Post: 01-31-2012, 08:52 PM
  3. Problem with side finish (bottom finish is great)
    By tikka308 in forum Tormach Personal CNC Mill
    Last Post: 11-19-2010, 03:40 PM
  4. 32 finish at bottom of pocket
    By BROCD in forum MetalWork Discussion
    Last Post: 03-03-2006, 02:26 PM
  5. Z Level Finish
    By Mortek in forum OneCNC
    Last Post: 02-05-2004, 06:02 AM
