586,100 active members*
2,743 visitors online*
Results 1 to 8 of 8
    Mar 2011
    68
    Solidcam Turning multiple coordsys
    Hello,
    I need help for a problem.
    I have a part in turning mode, that have 2 clamps.
    How can I put the second origin for clamp 2, that I can have a good simulation for the other side?
    For example, I have a contour on a side, and on the other side, is a hole(see picture attached).
    Wait for an answer.
    Have a great day!
    Mar 2011
    68
    Re: Solidcam Turning multiple coordsys
    Hello,
    Nobody can give an answer?
    is it impossible to do in SolidCam?
    Jun 2003
    1365
    Have you watched any of the videos or read any of the manual? Just add another coordinate system to the other side if you need one there. Add as many coordinate systems as you wish to have.
    Oct 2013
    153
    Seems like we can't do that with turning ! . If you add a second coordinate it removes the first one and creates the second coordinate . Not sure why !
    Mar 2011
    68
    Hello,
    Thanks for answers.
    As imachining-6061 said, it did not work, I do not know why.
    I finaly found a solution, from machine setup I modify the pp from TURNING to MILL-TURN.
    In this way it works great
    Maby somebody come with another solution!
    Thanks again!
    Oct 2013
    153
    Of course mill turn will work
    Jan 2014
    I found the same problem so unless you make a model file of part after first op. I haven't found a way to save the part after simulation
    I will try mill/turn now
    Nov 2015
    Yeah, In order to do multiple coordinate systems you will need to use MillTurn, Turning does not like it when you try and add multiple systems...
  1. Weird CoordSys Problem
    By BTP in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-19-2015, 07:59 PM
  2. SolidCAM Turning
    By isaacrps in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-28-2015, 02:30 PM
  3. turning in solidcam
    By Rik H in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-19-2011, 11:00 AM
  4. Multiple Similar Profiles - CNC Turning SolidCAM
    By mr chris in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-04-2011, 11:20 PM
  5. SolidCAM CSS Turning
    Last Post: 07-21-2009, 07:46 PM
