586,058 active members*
4,449 visitors online*
Results 1 to 6 of 6
    Oct 2013
    185
    Backlash Compensation and more...?
    I was wondering if PathPilot offers any backlash compensation like Mach3, and if so how well does it work? Not sure how well backlash compensation on the software side works, but it would for sure be nice to be able to reduce the slop of the machine to a minimum.
    Also, I was wondering if it wouldn't be possible to feed the controller other information about "inaccuracies" of the mill so it can correct for it in realtime. This would be a really nice feature, but I'm not sure about its feasibility. Fore example: My table is not completely flat, one corner is lower than the others. Yes, you can/should adjust the table etc. but this is sometimes hard and only possible to a certain degree. It would be super helpful if I could use a z-probe to map out the table and then feed this information to PathPilot which then corrects for it on the software side. Same goes for making sure the axis movement is 100% parallel to the "precision" t-slot. I could just use an indicator to check for any inaccuracies, and then have the controller correct for it.
    Any though?
    Feb 2015
    57
    Re: Backlash Compensation and more...?
    I wish I had something valuable to add, but I'm VERY interested in this topic. I'd love to be able to input some custom data and have the software account for errors as best it can.
    Sep 2012
    1543
    If it's based on linux cnc then it should be easy. I never used it myself tho
    As for the rest, Just use soft jaws, then it doesn't matter what is going on with your table (or put a fixture plate on it, to hold your vises)
    Jun 2006
    340
    How bad is the error in the table?
    Feb 2015
    57
    Quote Originally Posted by BAMCNC.COM View Post
    I'm using the stepped soft jaws. That was the first part I made on mine. On the other hand, I'm going to take some well given advice (probably from you, if I recall) and relevel my mill stand so that it isn't so damn level (the coolant doesn't drain very well). Then I'll retram the mill head after that thanks to another useful TKC's video and that awesome tram gauge.
    Feb 2009
    42
    Just have to add BACKLASH = 0.XXXX to your Axis config in the .ini file.
  1. Backlash compensation
    By lumberjack_jeff in forum LinuxCNC (formerly EMC2)
    Last Post: 01-19-2010, 05:15 AM
  2. EMC Backlash compensation
    By CROSSHATCH in forum LinuxCNC (formerly EMC2)
    Last Post: 01-19-2009, 07:30 PM
  3. Backlash Compensation
    By solek in forum Benchtop Machines
    Last Post: 03-05-2008, 08:22 AM
  4. Backlash Compensation
    By cnccustom in forum Mach Mill
    Last Post: 11-22-2007, 02:33 AM
  5. Backlash Compensation
    By utengineer04 in forum MetalWork Discussion
    Last Post: 04-26-2005, 05:42 PM
